Input Lag: Impact of Front Porch, Sync Porch, Back Porch, Blanking, Total, and Sync Polarity Settings
m2or
Post by m2or » 26 Sep 2023, 04:14
Stumbled across this thread and was wondering if these settings have any effect on input lag at all, I tried to lower and I don't understand what is better minimum timings, or VT (QFT), I want to find out which of these has the lowest latency.
Re: Input Lag: Impact of Front Porch, Sync Porch, Back Porch, Blanking, Total, and Sync Polarity Settings
Post by RealNC » 26 Sep 2023, 09:16
m2or wrote:
26 Sep 2023, 04:14
QFT. Minimum timings don't accelerate the scanout, and thus don't affect input lag. QFT does.
m2or
Post by m2or » 27 Sep 2023, 22:57
RealNC wrote:
26 Sep 2023, 09:16
m2or wrote:
26 Sep 2023, 04:14
To get the lowest latency I need to lower the horizontal total, or raise it?
Post by RealNC » 28 Sep 2023, 03:59
m2or wrote:
27 Sep 2023, 22:57
Horizontal total doesn't matter. Only vertical total does. The higher the VT, the lower the latency. So if lowering HT allows you to use a higher VT, then just do that.
However, with that being said, don't expect any significant improvements in latency with QFT. When you run your display at its maximum refresh rate, you're already using close to the maximum VT the display can handle anyway. QFT is mostly useful when you want to run your high refresh rate (like 240Hz) display at 60Hz without VRR and use QFT, giving you the scanout speed of 240Hz while running at 60Hz. And if you're using VRR (gsync/freesync), then QFT happens automatically anyway, so you don't even need to bother. Running the display at 240Hz but enabling VRR and capping game FPS to 60 will automatically result in 60Hz + QFT with a scanout speed of 240Hz.
m2or
Post by m2or » 28 Sep 2023, 05:40
RealNC wrote:
28 Sep 2023, 03:59
m2or wrote:
27 Sep 2023, 22:57
there must be some correct ratio? For example, "Front Poch + Sync width = Back porch" - Front Porch and Sync Width default to 116/3 and 144/4, But I only increase the vertical setting of the back porch to 393 to get a total of 1360 is this correct?
