Early Asus VG248QE 144Hz 1ms overclockable?
Posted: 09 Dec 2016, 13:56
by BTRY B 529th FA BN
I've got an early VG248QE, are they known to overclock at all? Do they break if you overclock them?
Re: Early Asus VG248QE 144Hz 1ms overclockable?
Posted: 09 Dec 2016, 19:26
Just seen they max out at 150Hz
link:
https://www.monitortests.com/forum/Thre ... 720p-200hz
The VG248QE will not accept anything higher than 150 Hz, and it can't handle that properly at the native resolution.
It's possible to get 150 Hz at 1280x720 and 1600x900 with these timing parameters:
H: 1280 24 32 24 80 1360
V: 720 3 5 5 13 733
H: 1600 24 32 24 80 1680
V: 900 3 5 5 13 913
Posted: 09 Dec 2016, 22:57
by lexlazootin
You might be able to go higher if you lower the vertical total or horizontal total some more.
But who knows, every monitor is different.
Posted: 10 Jul 2017, 11:03
by open
Mine goes to 145hz at 1080p. At 146 I see visual distortion and at 147 I get HEAVY visual distortion.
