AMD Overclocking help!!
Posted: 25 Aug 2017, 19:12
by JONNYFORGE
So i used the AMD Radeon settings panel to add custom resolutions like everyone says you are supposed to do. I have an Acer K272hl 60hz and an AMD R9 390, i was able to add a custom resolution all the way to 130hz before i got the "no can do" message. I restarted my computer, went to my monitor display settings and the highest available is 75Hz. So i figured i'd start by testing it on blur busters at 75hz before delving into why 130hz didn't show up. Blur busters doesn't even recognize the 75Hz. All of the tests say 60Hz and 60 FPS. I assume that means it's not working properly but in the display settings it SHOWS that 75 Hz is selected. I searched as much ss I could to find a solution in this forum and on google and I cannot find anything. Please help!
Re: AMD Overclocking help!!
Posted: 26 Aug 2017, 03:03
by RealNC
If you're on Windows 7, make sure Aero is enabled. It doesn't work without Aero.
If you're on Chrome, make sure GPU acceleration is used. Go to "chrome://gpu" to verify.
