Just FYI: this monitor doesn't overclock at all, at least not easily, beyond the factory 144 Hz, which I know is already fantastic, but just for curiosity's sake, would be great to see how much we can push it
I run it with an NVIDIA RTX card with G-SYNC enabled.
No matter how much I OC, 150, 165 Hz, etc, all of them frame skip. I tried messing with the vertical total and stuff like that and no dice.
LG 34GK950F Failed Overclock attempts
Re: LG 34GK950F Failed Overclock attempts
It appears you're getting successful-but-frameskipped picture (rather than "Out of Sync") when you increase refresh rate beyond manufacturer specifications.
That means your monitor is an excellent candidate for Quick Frame Transport (QFT) experiments, if you're a person who likes Low-Lag VSYNC ON.
Basically reducing the input lag of 144Hz via the use of ultralarge vertical totals!
You can try 144Hz + large vertical totals to try reducing VSYNC ON input lag a little bit via the "Quick Frame Transport" (QFT) effect.
Here's an advanced Advanced/Technical Quick Frame Transport HOWTO (you must be a CRU or ToastyX expert!) using RTSS Scanline Sync if you want to reduce the input lag of VSYNC ON to even lower lag than the existing low-lag VSYNC ON HOWTOs.
Note, that Quick Frame Transport (QFT) doesn't benefit VSYNC OFF because the frameslices are streamed onto the scanout in realtime (see high speed video of LCD scanout
This tweak may or may not be worth it, depending on how your monitor behaves with scanout acceleration (Quick Frame Transport)
Thanks for your reply Chief
However, this is a FreeSync monitor with a 48-144Hz VRR range, so I'm using it as a "G-SYNC compatible" monitor on my system
Definitely don't want to be hitting the refresh rate ceiling and dropping out of G-SYNC
Great, use FreeSync (GSYNC compatible) instead.rayw_bb wrote:Thanks for your reply Chief
It already benefits from quick delivery of frames so you don't need to do the "Quick Frame Transport" tweaks since it mainly benefits fixed-Hz VSYNC ON.
I have one of these monitors on the way in the next few weeks so I'll try the QFT hack and report back
Well... I was going to but I'm returning it. I just can't get used to the blur and strobe crosstalk even with blur reduction enabled. I think I've just been spoilt by ULMB TN panels for too many years
