Hello, I'm new to the forum. Last week my new AU9000, a 43-inch 4K TV has arrived. Its panel officially
supports @4K 60Hz VRR and @1080p 120Hz VRR. Since it's equipped with HDMI 2.0 i know there is bandwidth limitation.
I tried with CRU setting @1440p 120Hz (VRR off since with it i get very strange artifacts) and everything looks very blurry, it seems like vertical resolution has been halved. @1440p 60hz works perfectly fine.
Setting up the 120hz custom resolution i tried all the preset (even Reduced black), with no fortune. I think that's not a bandwidth problem as the screen is blurry even at lower custom resolution at 120hz. Is there something i am missing? What could i try?
Samsung 4K TV AU9000 unlock @1440p 120Hz
Return to “Display Overclocking”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
