Strobelight Beta 4 and Nvidia drivers
Whippy
Post by Whippy » 17 Feb 2024, 16:05
I have been using Strobelight Beta for longer than I remember on a supported Asus monitor. Recently I upgraded GPU drivers and GPU to something more modern. I am nearly certain that the latest Nvidia drivers aren't working with Strobelight. Is there a known driver list that is compatible? I have a GTX 1070ti.
Update: It seems to work, but the "lightbulb" icon on the task bar never lights up. It's like the software is unable to control the monitor brightness, nor do the hotkeys work. It could be that I am just using old tech and this is the best it's going to be. Even if that is the case, I can live with that. It's no CRT, but it's better than the average LCD.
Re: Strobelight Beta 4 and Nvidia drivers
Post by RealNC » 18 Feb 2024, 03:28
Whippy wrote:
17 Feb 2024, 16:05
Moved to strobing section.
Whippy
Post by Whippy » 18 Feb 2024, 08:03
RealNC wrote:
18 Feb 2024, 03:28
Thank you! I hadn't seen this section on first glance. Keep up the great work.
