http://www.amd.com/en-us/press-releases ... jan05.aspx
Here's the confirmation that it's IPS: https://twitter.com/amd_roy/status/552165728439111681
BenQ announces 144hz 1440p FreeSync [XL2730Z]
Re: BenQ announces 144hz IPS 1440p FreeSync [XL2730Z]
Wonder which panel this is...a new one, presumably
The IPS is unconfirmed but BENQ Blur Reduction is confirmed!
http://www.blurbusters.com/benq-confirm ... -freesync/
Re: BenQ announces 144hz (IPS?) 1440p FreeSync [XL2730Z]
So this is it, huh? 144hz IPS with blur reduction?
No freesync/gsync I take it?
Hmm. This is the perfect CSGO Monitor.
Asus VG248QE with GSync. Blur Busters GSync Contest Winner.
It's possible AMD made an error -- referring to other IPS FreeSync monitors.PoWn3d_0704 wrote:So this is it, huh? 144hz IPS with blur reduction?
I've never seen an IPS panel with a "1ms GtG" rating, so I'm needing a few confirmations...
Fingers secretly crossed, though!
Yeah, for sure. The problem is that a LOT of people here wont buy something until you've given it the green light Chief.
Re: BenQ announces 144hz 1440p FreeSync [XL2730Z]
My gut tells me 8 bit TN like the swift
I just saw this monitor in operation at CES 2015 in AMD's showroom:
http://www.blurbusters.com/amds-freesyn ... -ces-2015/
It looked like an 8bit TN to me; better than average for TN, but not with IPS viewing angles.
Couldn't you ask them what it was?
Since Gsync can't run with ULMB mode active, I was wondering if Benqs motion blur reduction will work while freesync is active.
Any word on that?
Any word on that?
