Benq ML2441 Dimming/auto brightness
mackandelius
Post by mackandelius » 20 Jun 2015, 06:06
I've had this problem for a while and have not found any sulution yet.
The problem is that if there is a dark backround my screen becomes darker which is really anyoing. I have gone through the manual several times but haven't found anything yet.
lexlazootin
Re: Benq 2441 Dimming/auto brightness
Post by lexlazootin » 21 Jun 2015, 06:27
Dynamic brightness adjustment... they use it to claim they have a better dynamic range then they really do. I have a monitor with this gimmic and you should be able to turn it off in the OSD. it might just be called "DBA" or something like that.
mackandelius
Post by mackandelius » 21 Jun 2015, 14:32
Look under this
mackandelius
Re: Benq ML2441 Dimming/auto brightness
Post by mackandelius » 21 Jun 2015, 14:45
Well i seems i have found the option it was called DCR so you where on the right track so thanks.
