Hey, thanks for clicking this and dont worry, I did read all threads I could find with the google search. I know about the firmware update on old monitors, what ama is for and the thing with ghosting.
So my question, I read many different things, causing my confusion.
Is high or premium faster, idc about ghosting/fraction/picture quality, which is the faster one, when do I see the enemy the fastest? Is there any real test about this exact thing?
Thanks for any help, input, or links. I really appreciate it!
High/Premium "AMA" on the Benq XL2430T?
Re: High/Premium "AMA" on the Benq XL2430T?
Premium is bit faster with a cost of more added overshoot.spacencs wrote:Is high or premium faster, idc about ghosting/fraction/picture quality, which is the faster one, when do I see the enemy the fastest? Is there any real test about this exact thing?
tldr: If you notice overshoot (artifacts) and don't like it then use AMA: High. If your don't notice overdrive (artifacts) then use AMA: Premium.
Read "Response Times" section at http://www.tftcentral.co.uk/reviews/benq_xl2730z.htm for details.
Yes it's another panel but it's BenQ AMA.
If compare an average G2G for Premium it's 2.3ms and for High it's 3.1ms.
So you will see enemy in 0.8ms faster in average while your reaction time must be 120-200ms
That times above is for XL2730Z but I'm sure times and difference won't change dramatically for XL2430T.
So again if you notice overshoot (artifacts) and don't like it then use AMA: High. If your don't notice any overshoot (artifacts) then use AMA: Premium.
By my experience at my setup (fps game with high brightness set) any overshoot don't bother me so I used premium.
Wow, thanks. That was so on point and really well explained. Thanks for the fast help, have a good day
