Acer XB270HA 27" 1080p 144hz
0134RY73
Re: Acer XB270HA 27" 1080p 144hz
Post by 0134RY73 » 20 Nov 2016, 11:53
Can somebody please upload icc profile, jeez thousands of you must have it.
Post by jorimt » 20 Nov 2016, 13:19
0134RY73 wrote:Can somebody please upload icc profile, jeez thousands of you must have it.
If it's someone's profile calibrated specifically for their monitor, it won't help yours anyway. In fact, it will more than likely make it worse. Even if you own the same monitor model as someone else, each panel is physically different. The offsets that are adjusted by the profile to properly calibrated his monitor are going have completely different starting points on yours.
If you don't have your own calibration device, you're better off using the brightness and contrast settings he posted and leaving your color profile at the default.
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
