Blur Busters Forums
Benq xl2411z cant get higher than 60hz even with DVI D Help!
Everything about displays and monitors. 120Hz, 144Hz, 4K, 1440p, input lag, motion tests & TestUFO, monitor decisions, and more. Questions? Just ask!
Postby barias » 11 Jan 2017, 12:27
Hi I Have Benq xl2411z monitor and idk why i cant use it on 100,120 or 144hz i can only use on in 60hz it keep saying incorrect cable please use the DVI D cable that came with your monitor!
My GPU is GTX 960
PLZ Help :cry:
barias
Re: Benq xl2411z cant get higher than 60hz even with DVI D H
Postby RealNC » 11 Jan 2017, 15:05
Try another DVI port on your graphics card.
Postby barias » 11 Jan 2017, 15:12
i have only one in the gpu
barias
Postby RealNC » 11 Jan 2017, 15:33
What kind 960 is it? Can you post a link?
And btw, ARE you using the DVI cable that came with the monitor? :-P
Postby barias » 11 Jan 2017, 15:43
https://www.msi.com/Graphics-card/GTX-9 ... o-overview
i did not get a dvi with it but i did buy a new DVI D
barias
Postby RealNC » 11 Jan 2017, 17:11
DVI-D is something different than DL-DVI.
You need a DL-DVI cable. DVI-D just means it's digital, as opposed to DVI-A, which is analog, or DVI-I which is both. All of these can be dual link (DL) or single link (SL). You need a DL-DVI cable. (When you buy it, it must say "Dual Link".)
Postby barias » 11 Jan 2017, 18:23
it says it supports Dual Link
barias
Return to General - Displays, Graphics & More
Who is online
Users browsing this forum: No registered users and 7 guests
