1440p Advice, XL2730/35 blur reduction. Best options?
Re: 1440p Advice, XL2730/35 blur reduction. Best options?
You can also try 165Hz. You can enable support for that mode in the OSD.
My panel just shits in pants if I try 165z, wont accept the OC.RealNC wrote:You can also try 165Hz. You can enable support for that mode in the OSD.
So I'm torn between
BenQ ZOWIE XL2730
Acer Predator XB241YU
Anyone have experience with these panels? Not fussed about g-sync. And am tempted to go back to 24" tbh.
1440p is a must, as is some sort of blur reduction tech for anyone wanting to recommend something else.
Many thanks,
Coe.
BenQ ZOWIE XL2730
Many thanks,
Coe.
Avoid the XL2730. It's buggy.
The fixed scaler is in the XL2735.
Ok thanks,
Unfortunately the XL2735 is out of my price range as I wont be able to sell the Acer to cover the cost Expecting to loose at least £100 on it.
