Questions about new G-Sync monitor
parini
Re: Questions about new G-Sync monitor
Post by parini » 01 Jul 2017, 22:44
Was unlocking for rtss and game
Post by jorimt » 01 Jul 2017, 23:21
parini, are you using only RTSS or the in-game FPS limiter to limit to 162 FPS?
Don't use both at the same time. Use only one.
Also, are you sure you are at 165Hz? Can you embed a screenshot of this to confirm:
parini
Post by parini » 02 Jul 2017, 01:12
Post by RealNC » 02 Jul 2017, 02:42
If the stutter issue is specific to League, this might be relevant:
https://support.riotgames.com/hc/en-us/ ... gh-End-PCs
This seems to be a VERY new issue (only 3 days old.)
Post by jorimt » 02 Jul 2017, 09:18
parini, you are definitely at 165Hz, thanks for the image.
If you are using G-SYNC + V-SYNC + 162 FPS limit with RTSS or in-game limiter (again, don't use both, use only one), the only way you can be getting stutter, is if the game is causing it.
Have you tried turning G-SYNC and V-SYNC off, and seeing if the games are still stuttering? If they are, G-SYNC can't fix that stutter.
parini
Post by parini » 02 Jul 2017, 11:31
I'm using the rtss to limit it, the funny one when the fps gets unlocked to stutter some.
parini
Post by parini » 02 Jul 2017, 12:21
I'm playing gta as I walk in the car on top of a light shines more than the others on the monitor is this normal?
Post by jorimt » 02 Jul 2017, 12:37
Without a better description, I have no idea what you are talking about. Can you take a picture with your camera for me to see?
parini
Post by parini » 02 Jul 2017, 12:56
I just filmed
