For best colors, the 165Hz IPS GSYNC displays are great.
For lowest lag (by a few milliseconds), the 240Hz TN GSYNC displays are great.
In addition to the ability to vary refresh rate to match frame rate (and eliminate erratic stutters caused by frame rate changes), GSYNC can also give you the reduced-lag "perfect VSYNC ON look" for any locked frame rate within the monitor's refresh rate range.
If your game is running at 47fps, your monitor is already automatically 47Hz for smooth motion. No even multiples needed.
Support Blur Busters: List of G-SYNC Gaming Monitors
Will 60FPS lock game have any jitter/stutter? on gsync 165hz
Re: Will 60FPS lock game have any jitter/stutter? on gsync 1
