Just wondering if anyone Has? If So, how high did you get? How?
What are the chances of breaking mine if I try?
Has anyone overclocked at benq xl2540?
- lexlazootin
Re: Has anyone overclocked at benq xl2540?
Typically Benq's don't overclock well at all, the most you get is like 2HZ it just frame skips if you go higher.
I personally have never busted a monitor from overclocking or heard of anything, it probably could happen i just don't think it would.
That said, BenQ/Zowies does custom Hz very well. They are generally fully refresh-rate multisync.
If you need 237.5Hz or 117Hz or whatever, the BenQ/Zowies will usually merrily do them (with no frame skipping) if it's below the maximum Hz.
Just wanted to say that with the latest few nvidia drivers (running a 1070 not OC'd), my friend has been able to achieve a higher than 2hz overclock on this monitor. It's just a modest 6hz, but I think it's impressive considering I have not been able to get more than 2hz out of zowie monitors myself.
Must be done with CRU of course. It works for me.
I have tested it as well and there was no frame skipping or any other similar issues I could find myself, but I'm very amateur at this still. If anyone can find a way to improve on these values, I would love to see it. I was using it in Overwatch with success, though the difference between 240 and 246hz is so minor as to be purely for bragging rights.
I want to corroborate the above post as well, I was able to do custom hz below 240 and above 144 very easily without frame skipping, such as when I was testing 185~ or so with blur reduction.
I want to also note that, when I downgraded to 388 series nvidia drivers and not 398, I was unable to do this. It would just give the out of range error.
Additionally, I used it for multiple days, weeks, without issue. So there are no stability problems with this very modest 6hz increase on scary zowie monitors.
https://pcpartpicker.com/list/Zwn2Gc upgraded for vr
Does that overclock still work with blur reduction enabled?
Sent you a PM, by the way.
I have not tried it with blur reduction enabled and I currently broked my PC doing some risky delidding so it will be a while before I can try it again.Falkentyne wrote:Does that overclock still work with blur reduction enabled?
Also apparently I can't use PMs until a certain number of posts? So I can't read your PM.
You can contact me on discord Felicity#0001 if you have it, or [email protected].
will lowering the resolution enable a higher oc ?
