Desk Setup Thread! [POST YOUR PICS]
Re: Desk Setup Thread! [POST YOUR PICS]
Case: Fractal Design Meshify C Black with 7x BeQuiet Silent Wings 3 140mm/120mm (two under GPU)
+Aquacomputer Quadro Controler with RGBx Lighting Monitor Set
GPU: GTX 1080 Ti AORUS 11GB OC
CPU: i7 8700k Delid (4,9GHz /1.37v)
CPU Cooler: Noctua NH-U14S
Mobo: MSI Z370 Gaming Pro Carbon
Power Supply: Seasonic Focus Plus 750W Gold
RAM: 16GB G.Skill Trident Z DDR4 3600 CL15 1.44v OC
HDD: 2x SSD Samsung 850 Evo 500GB
Monitor: LG 24GM79G-B 144hz 1080p -> trying to get new 240Hz
Headphones: Beyerdynamic Custom Game + AudioQuest DragonFly Cobalt DAC
Mouse/Keyboard: Logitech G305 (modded = 80g) + HyperX Alloy FPS Pro Cherry MX Red
Mousepad: CORSAIR MM350 XL
More photos:
https://imgur.com/gallery/1fVmFKH
Ill be posting mine soon
- IMG_1636100.jpg (514.41 KiB) Viewed 37614 times
Just a teaser, my desk setup will follow when it's ready
That's some serious PC work! What GPU is that?
Thank you, it's just a GTX 1080 FE that I bought at launch for a premium. It has lasted quite a while and I finally might put it to rest when the new RTX cards are out.
The beauty. If you have not finished this project. Try using 2 radiators.
You have hot water flowing from the processor to the video card, when you connect a second heatsink practically makes no sense. 4x120 will completely cope with heat from two components. But if you change the connection order, then you can apply cold water to both the processor and the video card. Look again at the picture.
Sorry but you do understand that a waterloop reaches equilibrium after some time. And at that point the order doesn't matter at all right? And that a waterloop is basically a closed system.1000WATT wrote: ↑02 Jun 2020, 13:00You have hot water flowing from the processor to the video card, when you connect a second heatsink practically makes no sense. 4x120 will completely cope with heat from two components. But if you change the connection order, then you can apply cold water to both the processor and the video card. Look again at the picture.
Also it's cold water entering the CPU then going to the GPU and on to the second radiator before going into the reservoir. Regardless, order doesn't matter whatsoever.
I been watercooling for over a decade. This build is 3 years old and my GPU never hits 55C.
