I've found some SLI input lag tests made with 1000fps camera.
I know CS:GO and SLI is overkill but it's about SLI principle.
without SLI average = 30.2ms
with SLI average = 38.6ms
https://www.youtube.com/watch?v=NpQPzg8 ... 87BHzftC6A
Some CS:GO SLI/VSync Input lag tests, with video evidence!
Re: Some CS:GO SLI/VSync Input lag tests, with video evidenc
very cool. Why does the LED turn on after the gun is fired tho?
the led is on when button is not pressed and off when pressed.
it would be interesting to see the input lag with/without sli when fps is completely unlocked.
ah, i should've read description more carefully (about LED turning off, rather than on).
more fps -> less input, I would say you need 200fps with SLI to balance the same input lag
This is why I never use SLI anymore, I go for the best single card solution now.
Can you do it again with the fps unlocked?
i can if you buy me another gtx 970
