I find it difficult and at the same time funny to represent your graph in the mousetester
Enable Network Card OnBoard Processor to finally fix wierd latency
Re: Enable Network Card OnBoard Processor to finally fix wierd latency
Because Realtek chips which are by the way used in most motherboards don't support hardware offload. So unless you have a fancy high end board with an Intel chip don't bother.
UPD: Okay, I googled your motherboard and it appears to have an intel chip so you could try fix from this thread.
something that actually improves things is to set the Interrupt Moderation Rate to minimal or off
type this in powershell:
Set-NetAdapterAdvancedProperty -Name "Ethernet" -DisplayName "Interrupt Moderation Rate" -DisplayValue "Minimal"
- BTRY B 529th FA BN
Would this be the same as IPv4 Checksum Offload, TCP Checksum Offload IPv4/IPv6, UDP Checksum Offload IPv4/IPv6: Rx & Tx ?
Sounds as if you have those off in your NDIS properties and you are skipping over the hardware settings and enabling them via windows registry?
From what I vaguely remember, and correct me if I am wrong, if those offload settings are not enabled e.g. Rx & Tx they rely on windows to process them which is much slower.
i messed with most of the settings from there, and the only one i decided to modify was the Interrupt Moderation Rate and i set it to minimal
