useplatformclock (Windows stutters)
LaggyTyp
Re: useplatformclock (Windows stutters)
Post by LaggyTyp » 11 Apr 2024, 14:26
bcdedit /set useplatformclock false
bcdedit /set useplatformtick yes
bcdedit /set tscsyncpolicy legacy
bcdedit /set disabledynamictick no
Post by Slender » 11 Apr 2024, 14:54
LaggyTyp wrote:
11 Apr 2024, 14:26
you not need any of that settings.
windows 11 uses RTC-tick by default.
for me, use disabledynamicktick in w11 cause problems with kernel timer (it stuck 983 us, without 0-3). same with useplatformtick yes.
w11 not need any bcdedit
upd: ahh, you set NO for DDT, i will try it.
