Awful Input Lag no matter what I do
MSIfanboy
Re: Awful Input Lag no matter what I do
Post by MSIfanboy » 05 Jul 2024, 02:57
makes me not want to buy zowies anymore, every zowie has high input lag according to this guy who reviews monitors
TimidNova
Post by TimidNova » 16 Aug 2024, 14:13
I wanted to come back to this after a guy sat down with me for free and helped diagnose my issue. My pc is fixed now thank god. It was a bios setting called Intel SpeedStep that was causing the issues. I'm not sure why it would cause such bad issues, but it does
With Intel SpeedStep:
Without Intel SpeedStep:
Post by Slender » 16 Aug 2024, 20:56
TimidNova wrote:
16 Aug 2024, 14:13
With Intel SpeedStep: Capture.PNG
Without Intel SpeedStep: after.PNG
your latency is high anyway
Screenshot 2024-08-16 185550.png (47.16 KiB) Viewed 4391 times
Simon95
Post by Simon95 » 17 Aug 2024, 05:10
Slender how do you archieve that low latency?
widow13
Post by widow13 » 17 Aug 2024, 16:54
Simon95 wrote:
17 Aug 2024, 05:10
Basic ops make a huge difference.
This is fresh formatted w11 with basic changes.
And ofcourse you can go with more advanced settings and make it even better.
Vocaleyes
Post by Vocaleyes » 18 Aug 2024, 07:18
TimidNova wrote:
16 Aug 2024, 14:13
Interesting. For both of those screenshots was anything running, were both usage scenarios the same?
Also, when you chenge settings to see kernel latency, does disabling speedstep have any effect on the results there?
Hyote
Post by Hyote » 20 Aug 2024, 22:28
Used to be lower than 1.9 but I'm testing again.
Post by Slender » 20 Aug 2024, 23:18
Hyote wrote:
20 Aug 2024, 22:28
good result. what pc spec?
Hyote
Post by Hyote » 21 Aug 2024, 01:38
Slender wrote:
20 Aug 2024, 23:18
Hyote wrote:
20 Aug 2024, 22:28
i9-10850k
RX 6900 XT
3200 MHz CL16 RAM
Post by Slender » 21 Aug 2024, 01:41
Hyote wrote:
21 Aug 2024, 01:38
Slender wrote:
20 Aug 2024, 23:18
Hyote wrote:
20 Aug 2024, 22:28
i9-10850k
RX 6900 XT
3200 MHz CL16 RAM
That explains a lot.
I can't achieve such a delay with nvidia graphics card and intel 12/13 generation.
e-cores breaks everything.
and sometimes get that nvidia spikes for no reason.
Screenshot 2024-08-20 235207.png (33.09 KiB) Viewed 3845 times
