11JimCarry wrote: ↑17 Mar 2025, 20:13win version ?buzzik wrote: ↑17 Mar 2025, 17:55My MinValuue was at 1 by default and I set it to 0JimCarry wrote: ↑17 Mar 2025, 10:07So when you load up fresh new ultimate power plan,the default of this is 100,of course it did not work me even that it was allready on 100 by default.buzzik wrote: ↑16 Mar 2025, 22:35UUPDATE:
So I think I finally figured this out... and it is very very simple...
All you need to do i s disable CPU core parking.
Here's a step-by-step guide:
1. Open the Registry Editor:
Press the Win key + R to open the Run dialog.
Type regedit and click OK.
2. Navigate to the Power Settings Registry Key:
Navigate to the following registry key: Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\0cc5b647-c1df-4637-891a-dec35c318583.
3. Modify the "Attributes" ValueMin:
Double-click on it and change the Value data from "1" to "0".
Click OK.
4. Find and Adjust "Processor performance core parking min cores"
Open your power plan (e.g., Balanced, Power Saver, High Performance).
Navigate to the setting called Processor performance core parking min cores.
Make sure it is set to 100%.
5. Restart Your Computer:
Restart your computer for the changes to take effect.
This has removed all desync and hit reg problems in all my FPS games along with stuttering and mushi mashi movements feeling. I've been playing for 3 days already and it works. You can even revert back all the temp fixes like scaling screens, etc.. I can finally enjoy gaming as I used to 10 years ago, in fact, my mouse input is so fast right now I need to relearn how to aim =)
Happy gaming gents!
"Setting:
Description:
Specify the minimum number of unparked cores/packages allowed (in percentage).
Subgroup:
Processor power management
Range, Units:
0 .. 0 %
Subgroup / Setting GUIDs:
54533251-82be-4824-96c1-47b60b740d00 / 0cc5b647-c1df-4637-891a-dec35c318583
Default value for schemes:
Ultimate Performance: AC=100
dont get me wrong but this is the default value you are showing why was your on 0? i dont know but the default is 100,so this is like 100% bs.
input lag and floaty mouse fix that is working for me
Re: input lag and floaty mouse fix that is working for me
now i get it why is yours is like this,i am using win 10,with latest updates,and when i load fresh new power plan this is how it looks?buzzik wrote: ↑18 Mar 2025, 05:1411JimCarry wrote: ↑17 Mar 2025, 20:13win version ?buzzik wrote: ↑17 Mar 2025, 17:55My MinValuue was at 1 by default and I set it to 0JimCarry wrote: ↑17 Mar 2025, 10:07
"Setting:
Description:
Subgroup:
Range, Units:
0 .. 0 %
- zz.GIF (26 KiB) Viewed 1114 times
glad it worked for you, i tried it on my setup but it did nothingbuzzik wrote: ↑16 Mar 2025, 22:35UUPDATE:
Click OK.
Happy gaming gents!
exactly,what win ver you are using ?jassine wrote: ↑18 Mar 2025, 14:01glad it worked for you, i tried it on my setup but it did nothingbuzzik wrote: ↑16 Mar 2025, 22:35UUPDATE:
Click OK.
Happy gaming gents!
Well well well... I had my week of happiness... Here we go again, this shit is back
What has been the best solution so far?
125% worked better for mezezozn wrote: ↑23 Jun 2024, 04:56Hi guys,
I have been trying to fix my input lag for a long time, and my hypothesis was that there is something wrong with my scaling because it was affecting all aspects of my PC, not just Valorant but also League and God of War, any offline or online game, and also my viewing experience on Twitch and YouTube.
I tried all the possible solutions that could be provided on this forum. I even bought a new PC and had an electrician visit my home to inspect, and we found nothing. While I was surfing the internet for a solution, I came across this video talking about Windows scaling by LinusTech watch?v=NF210WeR9C8&t=332s.
Then I thought to myself that maybe the scaling on my monitor (ViewSonic VX2428) is not right. For some reason, I always felt that the angles and FOV in Valorant are different and seem smaller than usual, and my game felt very different every time I changed the scaling options in NVIDIA Control Panel. Also, if I changed the in-game display from letterbox to fill, it had a different feel, but none gave the right feel for the game, and I still had my input delay problem.
Then I started to set a custom scale for my monitor. I started adding small percentages to my original scaling, which was 100%. I started with 101%, which was a bit blurry and didn't fix the problem, but I felt an enhancement in my game and mouse feel until I kept adding until I reached the value of 120%, which gave me a very crisp image for my desktop, and the taskbar was clean and crisp.
Then I hopped on a deathmatch, and everything was so smooth, and the angles were the right size and i could react to people and my movements were smooth. I then tried on a couple of different offline games like God of War and Ghost of Tsushima. My testing here was to parry the enemy as it was incredibly hard before and very unresponsive. Now, I was able to do that, and everything feels smooth again.
Bottom line is I tested on my side, and I want to share this solution with you guys. Maybe it may help you, and I'm really looking forward to your feedback on the matter and for you to test it for yourselves.
To change the scaling:
Right-click on your desktop and choose display options.
Choose scale and then custom scale.
Enter the value 120, then sign out and sign in again.
I hope this solves your problem as it did for me.
125% scaling = no fgloaty mouse??
This is interesting, scaling, resolution?
Check out what I wrote here: viewtopic.php?f=10&t=14518, my mouse movement is floaty too, I can only shoot better at resolutions lower than 800x600, for example, at 800x600 or 1024x768 I'm really bad, but of course, even with a lower resolution, it's still floaty, and I can barely see the people.
