Post
by jorimt » 24 Jun 2019, 09:54
I did know about that program, but I don't know if it's capable of that. Maybe someone else does here?
What I would also like to point out though, is that the max pre-rendered frames setting is just that: "max."
If you set it to "4" (and the override is respected by the test game), for instance, you don't all of a sudden have a constant 4 pre-rendered frames in the queue.
Instead, it simply allows the system to pre-rendered "up to" 4 frames; the queue can be filled with anywhere between 1-4 pre-rendered frames at any given time depending on what the system deems necessary to keep the game running smoothly (which further complicates attempts at testing this consistently).
Also, the pre-rendered frames queue typically only applies in GPU-limited situations (when the GPU usage is maxed), which is why we recommend a frame cap for the lowest input lag where possible, since whenever the framerate is limited by an FPS cap (which also indirectly prevents max GPU usage), the pre-rendered frames queue effectively no longer applies (effectively at "0").
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
