Blur Busters Forums
Which Monitor Do You Suggest For Using Pc And Console ?
Postby wNchstR » 18 Jul 2019, 07:06
I want to buy 1080p 24" monitor which I mostly use at 60 hz for console and also pc. After doing some reading I cant decide which one I should buy
Asus XG248Q
Viewsonic XG240R
Lg 24GL600F
Asus PG248Q
Which one do you suggest. Thank you.
wNchstR
Re: Which Monitor Do You Suggest For Using Pc And Console ?
Postby Notty_PT » 18 Jul 2019, 10:45
XG2402, XG240R and LG 24GL600 are your best bets for both console and pc gaming with good future proof for next gen consoles.
XG248Q is laggier at 60hz/120hz than the 3 I mentioned, faster at 240hz.
Notty_PT
Postby wNchstR » 18 Jul 2019, 13:18
Notty_PT wrote:XG2402, XG240R and LG 24GL600 are your best bets for both console and pc gaming with good future proof for next gen consoles.
Thanks for your answer. I have 2 choices. XG240 and 24GL600F. Which one do you recommend. Because of the stand, I am close to XG240. Which one' performance is better?
wNchstR
Postby Notty_PT » 18 Jul 2019, 17:00
Get the XG then! Amazing monitor, one of the best ever made
Notty_PT
Postby TTT » 19 Jul 2019, 09:07
Whichever you use make sure the monitor doesn't use a different scaler when you plug in HDMI.
The gsync 240hz screens are like playing on a laggy TV on console with HDMI because of this.
TTT
Postby wNchstR » 14 Aug 2019, 14:18
Do you know Asus PG248Q?
60-Hz-Overdrive „Normal“ İnput Lag: 1.2 ms
https://www.prad.de/testberichte/test-m ... -pg248q/6/
wNchstR
Return to Input Lag
Who is online
Users browsing this forum: No registered users and 7 guests
