I want to buy 1080p 24" monitor which I mostly use at 60 hz for console and also pc. After doing some reading I cant decide which one I should buy
Asus XG248Q
Viewsonic XG240R
Lg 24GL600F
Asus PG248Q
Which one do you suggest. Thank you.
Which Monitor Do You Suggest For Using Pc And Console ?
Re: Which Monitor Do You Suggest For Using Pc And Console ?
XG2402, XG240R and LG 24GL600 are your best bets for both console and pc gaming with good future proof for next gen consoles.
XG248Q is laggier at 60hz/120hz than the 3 I mentioned, faster at 240hz.
Notty_PT wrote:XG2402, XG240R and LG 24GL600 are your best bets for both console and pc gaming with good future proof for next gen consoles.
Thanks for your answer. I have 2 choices. XG240 and 24GL600F. Which one do you recommend. Because of the stand, I am close to XG240. Which one' performance is better?
Get the XG then! Amazing monitor, one of the best ever made
Whichever you use make sure the monitor doesn't use a different scaler when you plug in HDMI.
The gsync 240hz screens are like playing on a laggy TV on console with HDMI because of this.
Do you know Asus PG248Q?
60-Hz-Overdrive „Normal“ İnput Lag: 1.2 ms
https://www.prad.de/testberichte/test-m ... -pg248q/6/
Yea thats not the 240hz one, that is probably fine.wNchstR wrote:Do you know Asus PG248Q?
TTT wrote:Yea thats not the 240hz one, that is probably fine.wNchstR wrote:Do you know Asus PG248Q?
When we look the rates from Prad.de can we say the fastest console monitor for PG248Q ??
I don't know I'm not German.wNchstR wrote:TTT wrote:Yea thats not the 240hz one, that is probably fine.wNchstR wrote:Do you know Asus PG248Q?
Its a massive waste of money buying that primarily for console though, there are no future proof monitors for console really seeing as nobody knows solid info on the next gen either.
They will be Freesync2 over HDMI though, there still isn't many monitors even with that.
