Using enternally powered USB hub fix random mouse lag
Re: Using enternally powered USB hub fix random mouse lag
Post by Slender » 30 Jun 2022, 14:56
Chief Blur Buster wrote:
30 Jun 2022, 14:51
Slender wrote:
25 Jun 2022, 19:28
I also note that pci usb 2.0 devices use a completely different driver from the main controller.
A different USB driver triggered by a different USB hub, is also another good consideration.
Some USB drivers are better than others!
Just like with the graphics card driver, when using MS affinity tool, such a feature occurs.
Even when bound to a specific core, the driver still sometimes runs on 0 core.
mago
Post by mago » 05 Sep 2022, 11:30
try install
Intel hid event filter
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
Mr1991
Post by Mr1991 » 07 Sep 2022, 14:45
3xil3 wrote:
20 Jun 2022, 15:20
I actually had to Purchaed 2 external USB HUBs that has own power source. I originally tested with one and all good with 8k mouse and standard KB. But i have high end 60%ducky and for some reason power hog when plugged into same HUB much better but still wasn't %100. Now i got both plugged into their own dedicated USB hub that have own power source and lags all gone. Seem like MBs are not pushing enough juice to USB even more so when using the device RGB.
Which one did you buy?
