Did it fix your problem?Stimpy7314 wrote: ↑19 Mar 2023, 04:38I got a 3060ti now
I'm the OP just on a other acccount
apex legends not smooth
Re: apex legends not smooth
Its still choppy but better. Best improvement came from my new psu. With my previous psu i was daisy chaining the gpu cable. Now with my new psu i'm not. I think that made at least the biggest improvementSirito wrote: ↑23 Mar 2023, 22:49Did it fix your problem?Stimpy7314 wrote: ↑19 Mar 2023, 04:38I got a 3060ti now
If the other games you play are perfectly fine then it's Apex legends problem, actually many games suffers from microstutters and it's not the user's fault, I remember when I played Apex since like more than a year on GTX 1060 it had no microstutters, maybe they missed up with new updates.Stimpy7314 wrote: ↑24 Mar 2023, 05:46Its still choppy but better. Best improvement came from my new psu. With my previous psu i was daisy chaining the gpu cable. Now with my new psu i'm not. I think that made at least the biggest improvementSirito wrote: ↑23 Mar 2023, 22:49Did it fix your problem?
Yeah, i'm not the only one here.Sirito wrote: ↑27 Mar 2023, 00:20If the other games you play are perfectly fine then it's Apex legends problem, actually many games suffers from microstutters and it's not the user's fault, I remember when I played Apex since like more than a year on GTX 1060 it had no microstutters, maybe they missed up with new updates.Stimpy7314 wrote: ↑24 Mar 2023, 05:46Its still choppy but better. Best improvement came from my new psu. With my previous psu i was daisy chaining the gpu cable. Now with my new psu i'm not. I think that made at least the biggest improvement
I'm actually concerned that when they implemented nvidia reflex, shit went down hill. Because before the driver when they implemented reflex. It felt smoother and frametimes aren't janky.
- 8F6AB077-64F1-44A3-9F64-367881DE411B.png (124.46 KiB) Viewed 1717 times
