What is usb interrupt coalescing and how to disable it
Apparently doesn't work on win 11
Recently found this youtube channel, the guy posts a lot of interesting videos telling and showing you about stuff that you won't get spoonfed, which is literally free information so you don't want to miss out
Credit: RealJerryXOC#7693
(INTEL ONLY) An easy way to instantly lower input latency
Re: (INTEL ONLY) An easy way to instantly lower input latency
I wonder how to do this for amd?
Error - Driver cannot be loaded,re-installing the program may fix the issue.
intel 12400f
B660m asus prime D4
intel 12400f
B660m asus prime D4
- Tiberiusmoon
After looking around at various settings to reduce latency, at the end of the day I just stick to users who have external latency tests to backup their claims otherwise you don't know how much latency is reduced.
Sucks that you have to apply it every boot, wonder if there’s a way to make it permanent
This is interrupt moderation for Intel USB xhci controllers, Windows 8 and 10 both use 50 microsecond (us) interrupt moderation rate by default. It might help if you have mouse with more than 1000hz polling rate otherwise won't do much.
That is Eonds YT Channel
So what benefit does it have by disabling, if it’s already 50 mcs by default, which is already low?
