Input Lag with GSYNC
SachsenPowl
Post by SachsenPowl » 01 May 2023, 22:37
I have some questions about Input Lag and G-SYNC but found various answers...
Tl.dr to make it quick: what settings should i set for lowest possible Input Lag?
-"Games (like CoD MW2 WZ2) if fps >144 (my case 1080p) ->>>> G-SYNC + V-SYNC (NVCP)?, Ingame Limiter 141? Nvidia Limiter 141? Limiter trough ULLM Ultra (~138?), Reflex? HDR adds Lag?"
-"Games (like CoD MW2 WZ2) if fps <144 (my case 2160p) ->>>> G-SYNC + V-SYNC (NVCP)?, Ingame Limiter? Nvidia Limiter? ULLM On,Off,Ultra?, Reflex? HDR adds Lag?""
-what to set if there are other games, fps higher than refresh rate (Valorant, Quake, Unreal Tournament)?
-Does Input Lag change from native resolution to non-native?
-What if i change from 8bit to 10bit, RGB, chroma 422 etc?
Hardware is
LG 27GP950-B (latest FW) at 144Hz without OC at DisplayPort 1.4, connected with a Nvidia 2070 Super (Ryzen 5900X as CPU, 2x16GB 3800CL14 DDR4).
longer version:
I never played with G-SYNC before and tryed to get some knowledge about it but struggle with some things to get nearly as close to the optimum Input lag:
I usually play 2 games: Mainly CSGO and at the BlurBusters G-SYNC preview site (2014 <https://blurbusters.com/gsync/preview2/>) the best for input lag is ingame fps cap at 120 fps and G-SYNC/VSync enabled.
But at the Input Latency Master Sheet (<https://onedrive.live.com/view.aspx?cid ... 50hiq4wuf8>), the best for a 144Hz monitor, which I run, will be G-SYNC disabled and cap ingame fps_max 432 (3x144). Are these at general for all GSYNC Games or only SourceGames?
Second Game is CoD MW2 Warzone 2.0: i don't found any "valid" informations how Input lag differs on certain settings - at 2160p i get 90-100fps and at 1080p it will be +160fps - so what should I pick (nvcpl settings, ingame settings, ullm/reflex etc)?
I hope anyone can make it more clear for me
Re: Input Lag with GSYNC
Post by jorimt » 02 May 2023, 09:40
SachsenPowl wrote: ↑
01 May 2023, 22:37
1. Lowest possible latency will always be G-SYNC off + V-SYNC off + framerate as high above the refresh rate without maxing GPU usage.
2. Lowest possible tear-free latency is G-SYNC on + V-SYNC on + framerate within the refresh rate + GPU usage below 99%.
What you ultimately use is down to situation and preference, sometimes on a per-game basis.
As for no-sync + uncapped vs. G-SYNC + capped, start by reading the below:
https://blurbusters.com/gsync/gsync101- ... ettings/9/
Displays: ASUS PG27AQN, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
SachsenPowl
Post by SachsenPowl » 02 May 2023, 10:28
jorimt wrote: ↑
02 May 2023, 09:40
ULLM Ultra, On, Off? What about Reflex?
For both scenarios. G-SYNC at 4K, 100fps looks really good compaired to a bit washed out 1080p. But it feels that >160 fps has a bigger advantage than the better look.
Post by jorimt » 02 May 2023, 14:41
02 May 2023, 10:28
All three reduce render queue latency, but only whenever the GPU usage is maxed (99%+). When it's not, they're effectively doing nothing to reduce latency further.
Reflex is superior to LLM On/Ultra and is considered their replacement. Use it in games that support it where GPU usage is maxed the majority of the time.
As for LLM On/Ultra, they don't work in DX12 or Vulkan, even when enabled, so can only be used in some DX11 and older titles, and there isn't always a guarantee they will do anything in those either. It's game/engine dependent in most cases.
Another way to reduce render queue latency in scenarios you can't use LLM or Reflex is to ensure your framerate cap is the limiting factor 99% of time while it is also preventing maxed GPU usage, which will result in render queue latency reduction similar to Reflex.
SachsenPowl
Post by SachsenPowl » 03 May 2023, 12:46
Thanks for the explanation.
I have a few other questions:
Does HDR add some kind of input lag?
How important is the refresh rate cap at x.0000 numbers (not 143.999 -> 144.0000)
Post by RealNC » 03 May 2023, 13:07
03 May 2023, 12:46
With VRR it doesn't matter.
Post by jorimt » 03 May 2023, 15:15
03 May 2023, 12:46
Could depend on the monitor model (I.E. whether it has a G-SYNC module or not), but as far as I'm aware, usually little to none.
03 May 2023, 12:46
Similar to what @RealNC said, this rule does not apply to VRR, but only to low-lag standalone V-SYNC scenarios when limiting framerate with RTSS.
EDIT: just realized you meant rounding differences in physical refresh rate readouts, not decimal-level framerate limits. Either way, it still doesn't matter in majority of cases; I have a 240Hz monitor, and it shows as 239.97Hz in my OS, for instance.
SachsenPowl
Post by SachsenPowl » 07 May 2023, 05:52
Thank you.
On my previous Dell it was easy to "debloat" the EDID (software/driver) and get straight 144.000Hz
also it felt like a Day and Night difference if i loaded my delbloated profile.
On my 27GP950-B it makes no difference or i cannot feel it (non-GSYNC, fixed refresh).
