keyboard debounce/latency
Re: keyboard debounce/latency
Post by Slender » 08 Jun 2023, 20:17
F1zus wrote:
08 Jun 2023, 16:22
Slender wrote:
06 Jun 2023, 13:08
vyce wrote:
06 Jun 2023, 09:12
i bought dark project kd87a, it has optical switches, and the build quality is really good, but there is a problem - there is some input latency, that is noticeable in games.
my old hyperx alloy origins has no such problem, but i absolutely hate this keyboard.
i've figured out that the problem is in the pcb, but i have no idea is it even possible to fix
both keyboards have 1000hz polling rate btw
i have kd1b, good looking board, but yes, inputlag a lot.
you can resolve this to set 125hz in hidusbf.
https://blog.seethis.link/scan-rate-estimator/
Hello. I also have a kd3b keyboard and it has a slight delay. Tell me what do you mean by hidusbf? Need to download a modified driver from here https://www.overclock.net/threads/usb-m ... z.1589644/ ?
Or is it enough to download the software for the keyboard and change the polling frequency in it?
I changed the polling rate to 125Hz on the keyboard but didn't notice any difference.
https://github.com/LordOfMice
Post by Chief Blur Buster » 11 Jun 2023, 13:16
MatrixQW wrote:
06 Jun 2023, 13:21
I took the easy route and bought a ps/2 keyboard for 5€ instead of spending 100€.
That's one possible route, though may not be the ideal "esports way" since you get the low-Hz lag effect, though that can be the lesser of evil in many situations.
Now, what you did may be the lesser of evils, with zero contention and excellent keyboard mechanicals (if mechanical). Now, a good old mechanical keyboard, does have keyboardfeel advantages for some. That may outweigh.
Just FYI -- even in Amazon Europe, the PCIe USB cards are cheaper than that.
There's multiple problems to fight simultaneously:
- Latency from having too low keyboard Hz
- Latency from USB contention (interference between USB devices)
- Latency from keyboard mechanicals
MatrixQW
Post by MatrixQW » 13 Jun 2023, 18:25
PCIe USB is not very expensive, 15€ on Amazon. My problem is a good 1000Hz keyboard costs at least 100€.
According to Battle(non)sense, the faster ones are EVGA Z20 and Corsair K70 Rapidfire.
K70 1000Hz beats Z20 4000Hz.
Without videos like these, there is no way to know the latency of a keyboard.
Here is another one:
blurryboba
Post by blurryboba » 18 Jun 2023, 16:01
I have same keyboard. Sometimes when keyboard software enabled, it causes huge input lag when spamming a lot of buttons. After disabling software its back to normal
