i5-12500h
RTX 3060M (105W)
16GB DDR4@3200
1TB nvme
When i check my USB tree via device manager or usb viewer i see all my peripherals are connected to the same controller. All ports are getting used so i was wondering why this is the case. Ignore the USB Stick. Usually there is a USB mic attached.
My problem is a floaty, unresponsive mouse feeling in valorant.
Bonus question: anyone here has a recommendation and/or experience setting up processlasso for my 4p 8e-cores 16 threads cpu - only for valorant. I mostly run 0;2;4;6 + 4 e-cores the hyperthreads disabled because it gives my the most consistent frametimes in capframex.
Using 0-7 with e cores disabled gives me the most fps but i guess the HT causes some sluggishness. Using only the P-Cores gives me the best responsivness but can cause freezing and massive drops.
Up until now my config was
ProBalance off
HAGS on
Gamemode on
NV Threaded Optimization on
Priority high
I/O Priority high
Win32sep 16 /26 / 2a
W11 23H2
using bcdedit /set disabledynamictick does not change much
