Most low-latency PC options for new build
phaze
Post by phaze » 29 Nov 2023, 23:03
Hi,
I wanna know what do you guys think about those PC specs and which would achieve lower latency?
Also for gaming + streaming at 1080p90+ fps
CPU: Ryzen 7 7800X3D
Cooler: DeepCool AK620
MOBO: ASUS TUF B660 DDR5 ATX
GPU: MSI VENTUS 3X E OC 4070 12G
RAM: Corsair 6000MHZ CL36 32GB
SSD: Crucial P3 Plus 1TB
OR
CPU: Intel i7 14700K
Cooler: DeepCool LS720 360mm
MOBO: Gigabyte Aorus Z790 ELITE X AX
Also, does motherboard affect PC end to end latency when it comes to VRMs and good quality capacitors?
Thanks in advance.
Zodasaur
Re: Most low-latency PC options for new build
Post by Zodasaur » 30 Nov 2023, 13:13
For lowest latency get the 14700K. Intel's L3 ring bus is lower latency than AMD's infinity fabric.
I LOVE TIN FOIL
Post by I LOVE TIN FOIL » 07 Dec 2023, 15:42
Don't buy Gigabyte motherboards they are trash for DPC latency
Bobo
Post by Bobo » 07 Dec 2023, 18:10
I LOVE TIN FOIL wrote:
07 Dec 2023, 15:42
that and also their bios is horrible, it has lots of options that are hidden and can`t be accessed, you can only do it via 3rd party software.
joseph_from_pilsen
Post by joseph_from_pilsen » 08 Dec 2023, 07:39
Depends on model, i bought cheapest A620 gigabyte and it seems normal in DPC.. However this is AMD model.
phaze
Post by phaze » 08 Dec 2023, 14:14
07 Dec 2023, 15:42
So I go for ASUS TUF GAMING B650-PLUS AM5?
