8000Hz keyboards, are they needed?
Re: 8000Hz keyboards, are they needed?
If you have ad/hd i can not recommend wooting because it is so sensitive keyboard that you will always accidentaly move when you are not supposed to And if you raise actuation point you can compare it to some other keyboard that wont cost as much.
Have a Huntsman V2 and definitely not going back to Corsair after buying it. Keychatter is an abomination. It was noticeable considering the Corsair was already 1khz. The keys feel nicer too.
I don't think I would go to a keyboard with super low actuation as it's terrible for day to day use. Huntsman V2 LINEAR has adjustable actuation points on it, however I don't own that and wanted a more normal switch.
