internet latency & effects on hit registration
victor910
Re: internet latency & effects on hit registration
Post by victor910 » 13 Jul 2021, 00:59
You have completely no idea what you are talking about, that's sad
wadge
Post by wadge » 13 Jul 2021, 04:23
I’m asking questions, if you dont have an answer keep it shut coz ur not helping :arrow:
losxer
Post by losxer » 13 Jul 2021, 04:30
There Is no way for fix that , because isp too, dont know what cause this problem.
n1zoo
Post by n1zoo » 13 Jul 2021, 10:26
losxer wrote:
13 Jul 2021, 04:30
they don't know because It's not ISP related problem. But anyways you can try your 6th ISP provider, maybe this time you gonna be lucky!!
Unreazz
Post by Unreazz » 13 Jul 2021, 21:06
n1zoo wrote:
13 Jul 2021, 10:26
losxer wrote:
13 Jul 2021, 04:30
this wont do shit since youre using everytime the same infrastructur on youre grounding with any provider. you have to probably move to a new place and hoping that the problem is not occuring there
victor910
Post by victor910 » 13 Jul 2021, 22:15
I already had to change suburb, city, country and continent :).
So what must I change next? Planet?
Unreazz
Post by Unreazz » 14 Jul 2021, 06:33
victor910 wrote:
13 Jul 2021, 22:15
so where you living at the moment what kind of connection have you ?
victor910
Post by victor910 » 14 Jul 2021, 07:13
Brisbane/Australia 1 gigabits per second (real speed 700Mbits).
deama
Post by deama » 14 Jul 2021, 14:28
You can try elon's internet thing if it's available in your place, maybe his infrastructure will work better.
oldschool007
Post by oldschool007 » 14 Jul 2021, 18:44
according to my information there will never be packet prioritization on a dial-up connection like vdsl/ftth. i can say that for germany. Also it is not possible to turn off error correction or DLM/Assia.
it is probably only possible with a leased line or dedicated lines.
It is impossible to maintain quality standards or SLA's on a shared line. Everything is shared no matter if vdsl, ftth or cable internet. From my point of view the error correction is the culprit. Maybe the own line runs well and has few errors but on the main cable to the PoP are hundreds of other customers with lots of traffic etc.
I am trying a leased line with 4 mbit, direct connection to the backbone with packet prioritization from the 20th of july. If that doesn't work then i'm out :)
i think unfortunately until starlink works extensively it will still take. my feeling tells me but that it will not be optimal for gaming but i like to be convinced of the opposite.
Locked
