Let's try to make it public. Can we share this video with ASROCK/Gigabyte/MSI support? I think it will be easy for them to fix this with new bios?MontyTheAverage wrote: ↑07 May 2024, 23:30I don't know why It has happened to every system I have tried... I tried almost 10 different PCs/laptops with different specs. All same issuesn1zoo wrote: ↑06 May 2024, 11:21You won't really get anywhere with it. The real problem is identified in this video https://www.youtube.com/watch?v=j9TgNFu1l3Y I have had very little contact with this video maker, and this is surely the same problem that we are all here for. Jagged edges, low lod, pop-in, shimmering, floaty mouse feeling, hitreg issues, desynchronization - it all comes down to one problem. The problem with all this is that Intel ME or AMD PSP is said to be blocked and damaged, so the computer does not work as it should. This cause problems between the CPU and PCH bus. Worst of all, it is very difficult to solve. It is detailed in the video comments.
Petition for awareness
Re: Petition for awareness
I just installed an old intel me driver that came with my mobo and it fixed 2 problems that I had:
- After alt-tabbing windows explorer would be unresponsive for 20-30 seconds
- weird coil whine like noises when i moved the mouse in desktop
I wasn't aware intel me could cause such weird problems.
As the video creator says, this problem cannot be fixed on your current computer. He said it can only be fixed by buying a boxed cpu, a new motherboard and the original version of windows. And that's still no guarantee that everything will work perfectly. It's more like a lottery. In this case, it's better to buy a new computer outright from a person, or from a shop where you can test it before you buy it.dermodemon wrote: ↑11 May 2024, 11:49Let's try to make it public. Can we share this video with ASROCK/Gigabyte/MSI support? I think it will be easy for them to fix this with new bios?MontyTheAverage wrote: ↑07 May 2024, 23:30I don't know why It has happened to every system I have tried... I tried almost 10 different PCs/laptops with different specs. All same issuesn1zoo wrote: ↑06 May 2024, 11:21You won't really get anywhere with it. The real problem is identified in this video https://www.youtube.com/watch?v=j9TgNFu1l3Y I have had very little contact with this video maker, and this is surely the same problem that we are all here for. Jagged edges, low lod, pop-in, shimmering, floaty mouse feeling, hitreg issues, desynchronization - it all comes down to one problem. The problem with all this is that Intel ME or AMD PSP is said to be blocked and damaged, so the computer does not work as it should. This cause problems between the CPU and PCH bus. Worst of all, it is very difficult to solve. It is detailed in the video comments.
Here's footage of him on a fully correct PC. Video quality is beautiful, no noise, jagged edges and shimmering effect. The sens itself is low, but every pixel micro movement is instant and sharp.
https://youtu.be/FsT3KnKJeNM?si=-EPelTLFHs_2EJDh
More additional examples and context for this topic.
https://www.youtube.com/watch?v=wNjYleJCsR8
This is all quite promising. I’m sure for one person to fix a fundamental issue this large would be impossible, which is why the video creator stated so. But if a dev team were made aware of this issue it could be resolved potentially.
As it currently stands with regards to the statement of a real version of windows having an affect on this issue is rather a large claim. I wonder if there’s a way to prove this beyond reasonable doubt as I’m sure if that were done it would get the ball rolling much faster towards resolving.
Good work to the author for potentially identifying where the issue stems from!
You can disable the windows OS's ability to communicate with IME by disabling the appropriate hardware devices, and everything still will work just fine.
As in the pc will still boot and windows will run, yes 100%.
As in the specific issue highlighted in the video, care to provide proof in the form of the slowed down videos that everything is working fine in terms of video rendering smoothness? As the proof is in the pudding. Thanks.
you tested 4 different PC's LAN (mentioned in another post) and still had the problem, you tried several different builds and still you say about a "perfect" "like lottery" build and due to Intel ME or AMD conflict with PCH, loln1zoo wrote: ↑11 May 2024, 23:54As the video creator says, this problem cannot be fixed on your current computer. He said it can only be fixed by buying a boxed cpu, a new motherboard and the original version of windows. And that's still no guarantee that everything will work perfectly. It's more like a lottery. In this case, it's better to buy a new computer outright from a person, or from a shop where you can test it before you buy it.dermodemon wrote: ↑11 May 2024, 11:49Let's try to make it public. Can we share this video with ASROCK/Gigabyte/MSI support? I think it will be easy for them to fix this with new bios?MontyTheAverage wrote: ↑07 May 2024, 23:30I don't know why It has happened to every system I have tried... I tried almost 10 different PCs/laptops with different specs. All same issuesn1zoo wrote: ↑06 May 2024, 11:21You won't really get anywhere with it. The real problem is identified in this video https://www.youtube.com/watch?v=j9TgNFu1l3Y I have had very little contact with this video maker, and this is surely the same problem that we are all here for. Jagged edges, low lod, pop-in, shimmering, floaty mouse feeling, hitreg issues, desynchronization - it all comes down to one problem. The problem with all this is that Intel ME or AMD PSP is said to be blocked and damaged, so the computer does not work as it should. This cause problems between the CPU and PCH bus. Worst of all, it is very difficult to solve. It is detailed in the video comments.
I apologize but there is no logic, you are old at this and you know it.
btw, about the "ideal" PC, I already bought a complete PC from a pro tier 1 friend from my country, also a keyboard mouse from other professionals here and I still have/had the same symptoms, nothing has changed.
I've also been to a gaming house (as mentioned before you can look for the old posts) with several professionals without any problems and I still had them
Some nice anecdotes.loltakoo wrote: ↑13 May 2024, 18:31you tested 4 different PC's LAN (mentioned in another post) and still had the problem, you tried several different builds and still you say about a "perfect" "like lottery" build and due to Intel ME or AMD conflict with PCH, loln1zoo wrote: ↑11 May 2024, 23:54As the video creator says, this problem cannot be fixed on your current computer. He said it can only be fixed by buying a boxed cpu, a new motherboard and the original version of windows. And that's still no guarantee that everything will work perfectly. It's more like a lottery. In this case, it's better to buy a new computer outright from a person, or from a shop where you can test it before you buy it.dermodemon wrote: ↑11 May 2024, 11:49Let's try to make it public. Can we share this video with ASROCK/Gigabyte/MSI support? I think it will be easy for them to fix this with new bios?MontyTheAverage wrote: ↑07 May 2024, 23:30
But compared to the effort and proof provided in the videos without reciprocation, there’s not much to go on unfortunately.
It’s pretty easy to prvide a screenshot of me as I did to show whether it’s running or not at the very least.
If you’re still experiencing these symptoms but you can show us it’s running for you, that should be sufficient.
"Input lag" or "desync"—whatever you choose to call it—existed long before Intel ME or AMD PSP were first added to CPUs by Intel and AMD.
