Everything about latency. Tips, testing methods, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
deama
Post
by deama » 18 Apr 2023, 10:45
Slender wrote: ↑18 Apr 2023, 10:43
deama wrote: ↑18 Apr 2023, 10:38
Slender wrote: ↑18 Apr 2023, 10:35
deama wrote: ↑18 Apr 2023, 10:32
I set it to 0.5, and it gives me 0.4966 using ISLC
if you set 1ms, what value islc or timertool v3 show?
any bcdedit settings?
If I set it to 1, it gives me 0.9983 and gives me slightly worse DPC latency on the latency checker, though slightly more stable I think?
my am4 have 0.9996 timer.
hmm, am5 change it to 0.9983, strange.
0.9996/0.9999 best timer pick, always stable.
try to use for test:
bcdedit /set useplatformtick yes
it lock timer to 1000/500, but use RTC tick.
The DPC latency generally bounces a lot, typically it's sitting at around 15 micro seconds (or is it nano? The little u symbol), sometimes it jumps to 500 though when I am opening new applications or something is happening in the game, some games can maintain it at 15 micro seconds, other games I've seen it jump around to 500 more often.
Post
by Slender » 18 Apr 2023, 10:49
deama wrote: ↑18 Apr 2023, 10:45
i have same on intel. Check it.
viewtopic.php?f=10&t=11918
