MSI Optix MAG251RX OR AW2521HF Which one i should buy?
Smeell6
Post by Smeell6 » 16 May 2022, 10:04
Hello. I generally like to play competitive games, I'm stuck between these 2 monitors. Which do you think is more suitable for competitive games? Also I looked at a few videos, but AW looks better in terms of colors. i need your opinion
Also second question for both monitor :
As you know, you can't get 240 FPS in every game. I play a lot of CoD warzone and it's really hard to get 240 FPS in this game. So I'm wondering if the monitor works fine at fps like 144-160-180-200.Is MS always the same at these FPS Values? I want to get same performance at 180 fps.
Thatweirdinputlag
Re: MSI Optix MAG251RX OR AW2521HF Which one i should buy?
Post by Thatweirdinputlag » 16 May 2022, 16:10
You can check the Youtube channel "Hardware Unboxed" they do extensive testing on monitors in general, check if they did any testing on those. But in general, what you need to check is their response time, pixel refresh and ghosting around the fps that you normally get.
I got an IPS 165hz monitor recently "LG GP27850-B" and it is really buttery smooth as opposed to my previous 240hz Benq XL2456, because it just performs better at lower refresh rates "Game I play hits between 90-140fps. I also followed @Jormit's guide on how to properly use G-Sync. It also has better resolution, contrast ration, colour gamut, and viewing angles since it was one of the newest LG Nano IPS panels vs an older 2017 TN panel.
Rog Strix Z790i - Intel 13700K - 4090 OC ROG Strix - 7200 Trident G.Skill - 1TB SK Hynix Platinum P41 - 1000W ATX3.0 Asus Tuf - 34'' Odyssey OLED G8 - FinalMouse Tenz S/Pulsar Xlite V2 Mini - Wooting 60HE - Sennheiser HD 560s - Shure SM7b - GoXLR Mini
Discorz
VIP Member
Post by Discorz » 17 May 2022, 03:20
