Is this a timer fault?
Vocaleyes
Post by Vocaleyes » 01 Jul 2022, 05:23
Hi all, just asking the guys that know substantially more than i do about this. Is this supposed to happen, is it program compatability error with W11, or is this indicative of a timer fault?
Cheers in advance.
https://www.youtube.com/watch?v=1RY7tZ99H1A
Eonds
Re: Is this a timer fault?
Post by Eonds » 01 Jul 2022, 05:29
Vocaleyes wrote:
01 Jul 2022, 05:23
Cheers in advance.
That program doesn't work on windows 11.
kokkatc
Post by kokkatc » 01 Jul 2022, 12:34
Eonds wrote:
01 Jul 2022, 05:29
Vocaleyes wrote:
01 Jul 2022, 05:23
Cheers in advance.
I believe the program works just fine under windows 11, the timer just changed. In windows 11 when timer resolution is changed to .5ms, it's not always the same. You know it's still working by using latency monitor since dpc latency plummets when .5ms is enabled. You get the same behavior w/ ISLC in windows 11.
Post by Slender » 01 Jul 2022, 12:44
Vocaleyes wrote:
01 Jul 2022, 05:23
Cheers in advance.
windows 11 specific, just not touch or useplatformtick yes
Vocaleyes
Post by Vocaleyes » 01 Jul 2022, 16:12
kokkatc wrote:
01 Jul 2022, 12:34
Eonds wrote:
01 Jul 2022, 05:29
Vocaleyes wrote:
01 Jul 2022, 05:23
Cheers in advance.
And the default timer changing too is ok?
Vocaleyes
Post by Vocaleyes » 01 Jul 2022, 16:13
Slender wrote:
01 Jul 2022, 12:44
Vocaleyes wrote:
01 Jul 2022, 05:23
Cheers in advance.
I’m not sure what this means, please elaborate
Post by Slender » 01 Jul 2022, 17:14
Vocaleyes wrote:
01 Jul 2022, 16:13
Slender wrote:
01 Jul 2022, 12:44
Vocaleyes wrote:
01 Jul 2022, 05:23
Cheers in advance.
bcdedit /set useplatformtick yes
bcdedit /deletevalue useplatformtick --- revert
