AMD bios settings
Kyouki
Re: AMD bios settings
Post by Kyouki » 17 Aug 2022, 13:03
assombrosso wrote:
17 Aug 2022, 12:57
This is my response to this thread
https://twitter.com/s1mpleo/status/1559 ... FLg8-2P16w
Csgo best player don’t know what TPM even is, and you are out here spending 100 hours tweaking your mobo with 2% improvement xD
Different kind of interest or folks. You don't see a car owner tune his car just for the sake either. He just uses it as a transportation vehicle. :lol:
Sebichek45
Post by Sebichek45 » 01 Dec 2022, 09:52
Shieldsey wrote:
16 Aug 2022, 11:24
Testing a few of these out and, um say what, you may have just changed my entire gaming experience. Huge improvements to Halo Infinite especially.
As someone already said, it feels like a cheat code. 170hz of buuuuuttter.
Hello, can you tell me your current bios settings and why have you done so?
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 01 Dec 2022, 10:53
Updating Opening post to reflect changes that I'm using.
Markdh35
Post by Markdh35 » 06 Jan 2023, 00:05
Hello I'm new to the pc world.Ive just built my first pc but I'm struggling to get it running perfectly/smoothly.I came across this thread and tried to copy your settings however there ere quite a few that weren't in my bios.My system consists of-cpu:ryzen7 3700x,motherboard:msi mpg x570s edge max wifi,gpu:asus rog strix 3060ti oc v2,power supply:corsair cx750f rgb,ram:corsair vengeance lpx 3200mhz,monitor:benq zowie xl2540k.Im guessing the options aren't there for me due to mobo brand/model etc.Has anybody got any settings for my bios that will make my games run smoothly with very little latency please.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 20 Mar 2023, 23:14
updated OP.. links to the information cited in the post are dead
Segundo
Post by Segundo » 30 Mar 2023, 07:18
Does disabling TSME and Data Scramble work with AM5? I used all these settings and also disabled Power Down mode, enabled Resize Bar, enabled PBO, enabled EXPO II, disabled Memory Context Restore, set FCLK to 2000, and set UCLK equal to MEMCLK. I had to use the latter two since my PC wasn’t booting if I set those to Auto. If I use TSME and/or Data Scramble with EXPO II, my PC doesn’t boot.
I was finally able to disablr Power down mode since it refused to work for a long time. Does Power Down mode matter though since it’s not listed in your post? I suppose not being to disable these security settings isn’t the worst since I’m using my PC as a general purpose machine; it could be dangerous to turn these two off. Also, I do have an ASUS TUF GAMING B650-Plus Wifi, and it’s been widely reported that ASUS AM5 BIOSesbare awful and cause a lot of issues like not being able to boot and BSODs.
Additionally, I dont see a few of these settings. Do they have different names for AM5 or ASUS, or do they just not exist? I can’t find CPPC, CPPC Preferred Cores, APBDIS, SOC P-State, and NBIO LCLK DPM.
