Need Help Diagnosing Strange Bootup Behavior.
Re: Need Help Diagnosing Strange Bootup Behavior.
- like that.PNG (43.09 KiB) Viewed 1120 times
When that blurry thing happens, there's a key you can press to see if there's any diagnostics or warning messages that gets ignored boot. It's like tab or esc? or you can change the setting altogether on your bios settings, you could get lucky and board will tell you what's wrong. Maybe try disabling fastboot completely and see if it helps as it's usually set to enabled or auto for "medium boot".
Most adults need 7-8 hours of sleep each night. - US FDA
Usually have Fast boot disabled. I'll have to try pressing esc/tab when it happens next.DPRTMELR wrote: ↑20 Jul 2022, 16:10When that blurry thing happens, there's a key you can press to see if there's any diagnostics or warning messages that gets ignored boot. It's like tab or esc? or you can change the setting altogether on your bios settings, you could get lucky and board will tell you what's wrong. Maybe try disabling fastboot completely and see if it helps as it's usually set to enabled or auto for "medium boot".
From what you saying with the refresh rate changing try checking your Nvidia profile and if you do any type of overclocking check MSI afterburner and check if the profile is applied and it is not reset to default values if you found it did reset this means your graphics driver having a problem and resting on windows start for some reason I would suggest doing a clean install using DDU and installing the latest driver if this is not the case then I would suggest testing the monitor on another pc see if it is the problem if not try testing your GPU in another pc and see if the problem still exist if it does it might be hardware problem hopefully thermal paste change fix it if not then it needs to get checked out
for the weird stuff when booting I would suggest disabling CSM Support hopefully this was helpful.
Thanks for the suggestions, I appreciate it.sherifmagdy32 wrote: ↑20 Jul 2022, 19:02From what you saying with the refresh rate changing try checking your Nvidia profile and if you do any type of overclocking check MSI afterburner and check if the profile is applied and it is not reset to default values if you found it did reset this means your graphics driver having a problem and resting on windows start for some reason I would suggest doing a clean install using DDU and installing the latest driver if this is not the case then I would suggest testing the monitor on another pc see if it is the problem if not try testing your GPU in another pc and see if the problem still exist if it does it might be hardware problem hopefully thermal paste change fix it if not then it needs to get checked out
I don't have Nvidia Afterburner installed anymore (and I don't think I've installed it in this clean installation of Windows 11) Is there a chance settings get carried over (saved onto the GPU itself) through a clean installation of Window?
I am using EVGA Precision X at the moment to control my fan curve. It's been about 4 years since I've gotten this GPU, and I've never tried changing the thermal paste. Temperature wise, it seems like my temps are under control, they stay between 35-50C while gaming.
Have CSM support disabled. And, have been trying different drivers (latest few ones), and usually use DDU between them (when I'm not feeling too lazy).
Are you talking about the GPU drivers?MegaMelmek wrote: ↑20 Jul 2022, 12:34Last drivers from asus 6.3. 2020 only for windows 10 64bit.... no win 11.... its kinda outdatedxShino wrote: ↑20 Jul 2022, 10:34Yeah kinda, I have ASUS VG279QM and had the same issue, but I was always using an older Nvidia driver. After format I only used recent drivers, since then I didn't get this issue.I have same monitor as you and same behavior with the 144Hz sometime it boot with 144Hz and i can change it only by restart PC… It never hapend on Alienware monitor.. so i suspect monitor then…
I usually just check the latest from Nvidia and update to it (2022 drivers).
