Look at your GPUZ Bus Interface it is x16 PCIE GEN 1
Go BIOS set your GPU SLOT to PCIE GEN 4
5800x3d or 5900x 5950x
Re: 5800x3d or 5900x 5950x
if you mainly play DX11 titles, go with 5900 or 5950. If you are focusing on DX12 the 5800x3d seems to outperform everything.
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
Huh? No it's set to PCIe x16 4.0 @ x16 x.x is what it currently reports or uses, seeing 1.1 isn't weird and it is not GEN1. It'll turn down and turn up if there is enough load.
"max supported @(at) currently active"
Ok. I comment if it stuck at GEN1 He can try with GPU load maybe it is not changing to GEN4
- BTRY B 529th FA BN
I upgraded from the 3800X to the 5800X, and finally to a 3D. My main game I play is UT4 and occasionally CS:GO. The 3D is worth it without question with both games.
I think in csgo, fps don’t dip down a lot with the 3d right?BTRY B 529th FA BN wrote: ↑16 Aug 2022, 15:36I upgraded from the 3800X to the 5800X, and finally to a 3D. My main game I play is UT4 and occasionally CS:GO. The 3D is worth it without question with both games.
That's correct. You get higher minimums.assombrosso wrote: ↑16 Aug 2022, 15:58I think in csgo, fps don’t dip down a lot with the 3d right?BTRY B 529th FA BN wrote: ↑16 Aug 2022, 15:36I upgraded from the 3800X to the 5800X, and finally to a 3D. My main game I play is UT4 and occasionally CS:GO. The 3D is worth it without question with both games.
If you have a high HZ monitor, it's also worth getting 8K Hz input devices.
Is 8k hz mouse worth it for 240hz? And I heard many games aren’t compatible with it, and ppl have issues etc, what’s your experience with it?BTRY B 529th FA BN wrote: ↑16 Aug 2022, 16:17That's correct. You get higher minimums.assombrosso wrote: ↑16 Aug 2022, 15:58I think in csgo, fps don’t dip down a lot with the 3d right?BTRY B 529th FA BN wrote: ↑16 Aug 2022, 15:36I upgraded from the 3800X to the 5800X, and finally to a 3D. My main game I play is UT4 and occasionally CS:GO. The 3D is worth it without question with both games.
As long as you use it @ 8K-Hz @ 3200 DPI you should see an improvement. You're limiting factor will be your monitor with CSGO.assombrosso wrote: ↑16 Aug 2022, 18:21Is 8k hz mouse worth it for 240hz? And I heard many games aren’t compatible with it, and ppl have issues etc, what’s your experience with it?BTRY B 529th FA BN wrote: ↑16 Aug 2022, 16:17That's correct. You get higher minimums.assombrosso wrote: ↑16 Aug 2022, 15:58I think in csgo, fps don’t dip down a lot with the 3d right?BTRY B 529th FA BN wrote: ↑16 Aug 2022, 15:36I upgraded from the 3800X to the 5800X, and finally to a 3D. My main game I play is UT4 and occasionally CS:GO. The 3D is worth it without question with both games.
https://cdn.discordapp.com/attachments/ ... 66/DPI.png
https://www.youtube.com/watch?v=mwf_F2VboFQ
EDIT: also RTINGS ranks it second in click latency at 2.1ms
