Hi Guys,
Can anyone help me select the best settings for this monitor for fps games,mostly warzone ?
At the moment I'm playing with it set at 170hz (which is an overclock setting) Rtings review here https://www.rtings.com/monitor/reviews/ ... -vg27aql1a say that this is the lowest input lag but it does have some ghosting (which it does).
I've low latency mode turned on in Warzone on Ultra Gsync and vsync off.
What would you suggest the best settings would be to keep the input lag low with the best look?
I have a Rtx 3070 with settings turned down slightly and don't go above 170 fps.
Asus Vg27aql1a best settings for lowest input lag
Return to “Input Lag / Display Lag / Network Lag”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
