Asus Vg27aql1a best settings for lowest input lag
Posted: 01 Sep 2022, 09:30
Hi Guys,
Can anyone help me select the best settings for this monitor for fps games,mostly warzone ?
At the moment I'm playing with it set at 170hz (which is an overclock setting) Rtings review here https://www.rtings.com/monitor/reviews/ ... -vg27aql1a say that this is the lowest input lag but it does have some ghosting (which it does).
I've low latency mode turned on in Warzone on Ultra Gsync and vsync off.
What would you suggest the best settings would be to keep the input lag low with the best look?
I have a Rtx 3070 with settings turned down slightly and don't go above 170 fps.
