My monitor is a AG251FZ 1920x1080 @240hz and i confirm this model has a 1.2 dp port. I have 5.4 aswell
DP Cables
Re: DP Cables
Re: DP Cables
I have question my monitor is XL2430T 144hz
I using DVI-D if I change to DP cable
Can I feel any different? more smooth? less input lag?
Re: DP Cables
Re: DP Cables
Well, 5.4 means a 1.2 DP cable, to go further you need to upgrade to 1.4.Shade7 wrote: ↑13 Sep 2022, 20:49I have run the firmware updater a long time ago.
Tried again right now, and it says I already run it.
Is there anything else I have to do to get above 5.4 speeds?
If you are certain about your dp version, i have no idea, maybe your monitor support only 1.2 speeds.
Re: DP Cables
the cable did nothing for me
But I'm a DP 1.2 monitor (zowie xl2546) and GTX 1080ti. Although I did update the firmware.
Anyways, pretty sure I'll only get higher than 5.4 gbps when I have a monitor that supports DP 1.4 ... yet another reason to upgrade to the new zowie
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
Re: DP Cables
This is correct.Ragerlis wrote: ↑14 Sep 2022, 00:24Well, 5.4 means a 1.2 DP cable, to go further you need to upgrade to 1.4.Shade7 wrote: ↑13 Sep 2022, 20:49I have run the firmware updater a long time ago.
My 1080 ti and Zowie xl2546 was DP 1.2 and ran 240hz just fine at 1080p.
I then patched the GPU's firmware and upgraded my monitor to the Acer 390hz and voila! 8.1gbps link rate (DP 1.4).
