@Chief
Yup sometimes a "tweak" can be counter-productive and hurt the goal to lower latency.
There is some reg tweak CoalescingTimerInterval I think you're talking about
The weird thing about those different calls is my Timeframes were relatively the same with HPET vs ITSC
Our favorite DWM
Re: Our favorite DWM
Properly done, there's no difference if you distribute those microsecond interruptions evenly.BTRY B 529th FA BN wrote: ↑28 Sep 2022, 20:03@Chief
It's a lot of buggy drivers/OS with the conditions -- where you've got a converging situation, e.g. doing the timer events in a kernel driver and bøЯk3d it in a way to cause self-DDoS via storm of bunched timer events for consecutive starving of Ring 3 code execution (your coding + apps) for long enough to generate human-visible effects.
In that condition, major differences in performance of timer/DPC/etc processing in buggy drivers, that create self-DDoS-ing "event storms" can be key in fluidity of Ring 3 code execution for blocking driver events. Those kinda things that cause mouse-softcursor stutters (e.g. app-drawn mouse cursors instead of the windows hardware mouse cursor sprite or a Ring 0/1 graphicsdriver-drawn cursor) = also visible as pan stutters, mouseturn stutters, and scroll stutters.
So many dominoe effects that accidentally occur from sloppy temporal hygeine. Which didn't matter less at 60Hz but matters a chasm more at 500Hz and beyond.
I wish all coders were perfect (especially authors of kernel driver), but alas, it is not what it is...
Using this script - https://github.com/Ingan121/DWMKiller
