What system?deama wrote: ↑13 Apr 2023, 15:14Weird stuff, I normally get 12k+ on latencyMon, when I keep DPC checker on, it goes down to 500, and when I have ISCL intelligent list standby cleaner on at the same time, it hovers between 25-50 sometimes spiking to 500.
Can't quite explain it, but I think my mouse somehow feels better? I'll do some latency measurements using my 1k fps camera and see how that goes tomorrow.
Kernel timer latency?
Re: Kernel timer latency?
z790, all e-cores enable in bios, disable in OS.
Default bcdedit (only disabledynamictick), 22h2.
This is sweetspot 0.999 timer.
https://www.reddit.com/r/ASUS/comments/ ... mer_issue/
2.5 years intel can't fix timer.
- Untitled (1).png (207.91 KiB) Viewed 1819 times
Windows 10 22h2Slender wrote: ↑15 Apr 2023, 21:47What system?deama wrote: ↑13 Apr 2023, 15:14Weird stuff, I normally get 12k+ on latencyMon, when I keep DPC checker on, it goes down to 500, and when I have ISCL intelligent list standby cleaner on at the same time, it hovers between 25-50 sometimes spiking to 500.
cpu/motherboard?deama wrote: ↑16 Apr 2023, 16:09Windows 10 22h2Slender wrote: ↑15 Apr 2023, 21:47What system?deama wrote: ↑13 Apr 2023, 15:14Weird stuff, I normally get 12k+ on latencyMon, when I keep DPC checker on, it goes down to 500, and when I have ISCL intelligent list standby cleaner on at the same time, it hovers between 25-50 sometimes spiking to 500.
ryzen 7950x3d, gigabyte gaming x670, rtx 4080, 64gb ram g.skill 30-36-36-43-53Slender wrote: ↑16 Apr 2023, 16:11cpu/motherboard?deama wrote: ↑16 Apr 2023, 16:09Windows 10 22h2Slender wrote: ↑15 Apr 2023, 21:47What system?deama wrote: ↑13 Apr 2023, 15:14Weird stuff, I normally get 12k+ on latencyMon, when I keep DPC checker on, it goes down to 500, and when I have ISCL intelligent list standby cleaner on at the same time, it hovers between 25-50 sometimes spiking to 500.
what timer res by default? 0.9999, 0.9996?
I set it to 0.5, and it gives me 0.4966 using ISLC
my am4 have 0.9996 timer.
hmm, am5 change it to 0.9983, strange.
0.9996/0.9999 best timer pick, always stable.
try to use for test:
bcdedit /set useplatformtick yes
it lock timer to 1000/500, but use RTC tick.
