Everything about latency. Tips, testing methods, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
SKILLEN
Post
by SKILLEN » 20 Nov 2022, 14:16
Is this normal ?
High Performance mode
Disable C-states , Intel speedstep
Disable power saving for usb's
No bcdedit commands
Tried 3 mice Zowie S1 , Logitech G403 Hero , Zowie ec-2a
Same result every time with all mice
- moussehz3.png (51.25 KiB) Viewed 2349 times
- mousehz.png (55.32 KiB) Viewed 2349 times
InputLagger
Post
by InputLagger » 20 Nov 2022, 15:25
SKILLEN wrote: ↑20 Nov 2022, 14:16
Is this normal ?
No bcdedit commands
viewtopic.php?f=10&t=10565&p=85767#p85767
SKILLEN
Post
by SKILLEN » 20 Nov 2022, 18:43
InputLagger wrote: ↑20 Nov 2022, 15:25
Is this normal ?
No bcdedit commands
i saw this but what?
FPSMaster
Post
by FPSMaster » 21 Nov 2022, 05:43
What motherboard do you have? Are you using a USB PCIE card or the dedicated USB ports?
SKILLEN
Post
by SKILLEN » 21 Nov 2022, 17:27
FPSMaster wrote: ↑21 Nov 2022, 05:43
Asus B660M-A D4 ,today i bought some USB PCIE card - Orico PNU-3A1R-BK-BP - ,hz result is the same + internet port doesnt work ;D
FPSMaster
Post
by FPSMaster » 21 Nov 2022, 19:49
SKILLEN wrote: ↑21 Nov 2022, 17:27
Ok interesting... did you move your mouse in a circle fast? Or slow? This graph looks like you moved it slow. If you move your mouse slow, it will decrease its pollingrate based on the speed. That's what all mice do. Just wanna rule that out.
SKILLEN
Post
by SKILLEN » 22 Nov 2022, 10:37
FPSMaster wrote: ↑21 Nov 2022, 19:49
Nooo , i moved fast .
Can you show me your test ?
I tried again fast as i can.
- mousehz5.png (28.94 KiB) Viewed 1895 times
- mousehz4.png (24.8 KiB) Viewed 1895 times
FPSMaster
Post
by FPSMaster » 07 Dec 2022, 08:53
Sorry I'm a bit Late ^^
That was the reason why it looked like that. Thats completely normal!!! The little stutter there is normal too. Just type in the CPI count after the stutter. I saw its at around 1500 CPI. Type in 1500CPI inside "data point start" and you will see the correct graphs.
