PUBG input lag
Posted: 28 Nov 2022, 07:46
by ForZz54nsk
Hello. Please share your experience, advice, guides.
How to reduce the input lag in the PUBG game
how to optimize amd radeon, windows, network adapter. HPET default vs off?
Bios settings? - gigabite b550 elite v2
What are the best settings for this game?!
ryzen 5600x
rx 6600
32 gb ram 3600 cl16
Hp omen x25f
Re: PUBG input lag
Posted: 28 Nov 2022, 16:08
by Mr1991
No one size fits all, disable all power saving, same with bios, set clocks, disable anything you don’t need, disable anything you don’t need running in Windows, generally the less the better
Disable adaptive sync on x25f, use a decent hdmi cable, set response time, play with sharpness (this makes a noticeable difference on this monitor)
Re: PUBG input lag
Posted: 29 Nov 2022, 01:37
by ForZz54nsk
Bro, can I have a link to an HDMI cable that is perfect for my monitor?
Re: PUBG input lag
Posted: 29 Nov 2022, 04:01
by daviddave1
ForZz54nsk wrote: ↑29 Nov 2022, 01:37
Linus made a yt not long ago about the best hdmi cables.
https://www.youtube.com/watch?v=XFbJD6R ... usTechTips
Re: PUBG input lag
Posted: 29 Nov 2022, 04:16
by olofsson_tom
https://www.amazon.com/Cable-FIBBR-48Gb ... 255&sr=8-1
Re: PUBG input lag
Posted: 29 Nov 2022, 12:25
by Mr1991
General consensus is the shorter the better, and a thicker shielded one should also be best too, if a 1 meter cable can reach, use that
Re: PUBG input lag
Posted: 29 Nov 2022, 13:32
by imprecise
Unplug controller, pubg will take your keyboard and controller input at the same time.\
Also, I'm not sure why HDMI is being suggested. In my experience, most gaming monitors are better off with a good quality DisplayPort cable rather than HDMI.
Re: PUBG input lag
Posted: 29 Nov 2022, 14:16
by MegaMelmek
there is improve when you use optical HDMI/DP cable i repeat optical
