Not sure if this is the correct blog to post it on.
Does anyone have a idea why this:Performance state type: None isn't set to: ACPI Collaborative Processor Performance Control?
I'm aware that that feature need PSS Support & c-states to work. PSS is enabled and c-states is on auto (Setting it to enable wont work either). CPPC & CPPC pref cores are also enabled.
Here are my specs:
CPU: Amd ryzen 5 3600
GPU: Gtx 1660 super
RAM: Kingston fury beast 3200mhz 16-17-17-18-36
MB: Asrock b450m steel legend bios (i'm on agesa v1.2.0.7)
PSU: Corsair cv550
- {6CDE2CBF-D1E5-42C0-BB19-F02F47CD779D}.png (5.66 KiB) Viewed 2168 times
Re: Performance state type: None
did you enable x2APIC support in the bios? I believe that also breaks cppc.
AMD CBS --> CPU Common Options --> Local APIC ModeStimpy7314 wrote: ↑16 Jan 2023, 11:06Not sure if asrock has that option in their bios menu. But i can take a look. I'll keep u updated. Thanks for the tip
But it shouldn't be enabled by default so its most likely not causing your problem.
It does not show up in my bios, but grabbed scewin fast, its there. Current options are: Compatibility, xAPIC, x2APIC, Auto. Which one do i need to enable?Tell wrote: ↑16 Jan 2023, 11:48AMD CBS --> CPU Common Options --> Local APIC ModeStimpy7314 wrote: ↑16 Jan 2023, 11:06Not sure if asrock has that option in their bios menu. But i can take a look. I'll keep u updated. Thanks for the tip
I enabled x2APIC but its still showing up as "none"
Forcing x2APIC mode is what breaks CPPC. Sorry if I wasn't clear.
I only tested auto and then forcing x2apic. I'm not sure what the auto setting is defaulting to.Stimpy7314 wrote: ↑16 Jan 2023, 12:56Nah u were clear, i just didn't read it properly. Which one do i enable then besides x2apic?
Tried all options so far. Still at noneTell wrote: ↑16 Jan 2023, 13:02I only tested auto and then forcing x2apic. I'm not sure what the auto setting is defaulting to.Stimpy7314 wrote: ↑16 Jan 2023, 12:56Nah u were clear, i just didn't read it properly. Which one do i enable then besides x2apic?
