Did someone tried this open router guys? i'v heard only good things about it... It can bypass isp congestion
Maybe he can solve us internet desync caused by full congestion ISPs around our living area?? Did someone tried it?
https://evenroute.com/iqrouter
QIrouter
Re: QIrouter
As far as I know, only using a VPN can bypass ISP congestion. Check the 1-3 star ratings on Amazon, the 4-5 stars are literally all generic as if it was scripted. Plus, if it was a magical router, it should've been more mainstream don't you think? With a ton of documented reviews "youtube, reddit, etc" to go through.skkiNN wrote: ↑02 Feb 2023, 11:22Did someone tried this open router guys? i'v heard only good things about it... It can bypass isp congestion
Rog Strix Z790i - Intel 13700K - 4090 OC ROG Strix - 7200 Trident G.Skill - 1TB SK Hynix Platinum P41 - 1000W ATX3.0 Asus Tuf - 34'' Odyssey OLED G8 - FinalMouse Tenz S/Pulsar Xlite V2 Mini - Wooting 60HE - Sennheiser HD 560s - Shure SM7b - GoXLR Mini
Re: QIrouter
i got a VPS from amazon close to my city and guess what? first week a see for sure an improvement then it went back like heavy shit... im loosing my mind. If is "eletrical" i think we'r all fucked up. Maybe solar is the only way. If is internet, we have more chances to hit the point, then i was hoping someone maybe tried this router and things went better...Thatweirdinputlag wrote: ↑02 Feb 2023, 16:35As far as I know, only using a VPN can bypass ISP congestion. Check the 1-3 star ratings on Amazon, the 4-5 stars are literally all generic as if it was scripted. Plus, if it was a magical router, it should've been more mainstream don't you think? With a ton of documented reviews "youtube, reddit, etc" to go through.skkiNN wrote: ↑02 Feb 2023, 11:22Did someone tried this open router guys? i'v heard only good things about it... It can bypass isp congestion
Re: QIrouter
Okay, how exact it can bypass isp congestion? Make another dedicated 40Gbit fiberline from you to ISP and from ISP to another ISP?skkiNN wrote: ↑02 Feb 2023, 11:22Did someone tried this open router guys? i'v heard only good things about it... It can bypass isp congestion
Any super duper game features in router "OS" is QoS or DSCP marking, and any of that features cannot bypass your ISPs overloaded line or router. Or ISP's "ISP" line/router.
Its. Not. Possible. Period.
Any "open router" is linux distro + iptables. And if you will investigate it you will find it in mikrotik, netgear dumaos (okay, linux + gaming wallpaper + iptables), *WRT, pfsense etc.
Inside this "open router" you will find old MTK CPU, just because its looks like as OEM board and cheap plastic case from aliexpress, nothing more.
