Heavy mouse feeling
holiday
Re: Heavy mouse feeling
Post by holiday » 17 Mar 2023, 16:09
jorimt wrote:
17 Mar 2023, 13:22
holiday wrote:
17 Mar 2023, 13:09
No, markC set the binary’s to achieve a linear curve so there is no accel.
Since csgo use the smoothmousecurves somehow markC won’t work. You have to set all binary’s to 00.
Also the cpl or cheese mousefix won’t work (I know they are for wind xp) I used them for testing cause different binary values gives you a different mousefeeling.
That’s why ppl say win7 sens is different from 8, 10 and 11 in csgo.
Replace the "pretty much the same" from my original reply with "similar" then. I haven't used the MarkC fix for years myself because I assumed it wouldn't necessarily work as intended in the very latest versions of Windows 10 and 11 anyway.
I merely glanced at the post you linked and thought it looked very similar to the MarkC fix. The fact any of this has be considered to achieve true raw input in CS:GO on modern operating system is silly, for sure. The game needs an engine update.
Indeed, the engine needs an update. This problem exist since 1998 with the half-life engine. They add a work around m_filter. But this option is missing in csgo cause I guess valve thought rawinput will fix it but they need to fix their code in the engine. I mean why they use ingame commands for acceleration thresholds that winxp used in a game from 2012?
Post by jorimt » 22 Mar 2023, 17:33
holiday wrote:
17 Mar 2023, 16:09
Speaking of the devil:
https://www.counter-strike.net/cs2
Wonder if it will including any input updates?
Mugabi
Post by Mugabi » 22 Mar 2023, 18:07
jorimt wrote:
22 Mar 2023, 17:33
holiday wrote:
17 Mar 2023, 16:09
They have new tickless system where is there no ticks , I don’t how this gona get affected by electricity latencies issues.
Post by jorimt » 22 Mar 2023, 18:14
Mugabi wrote:
22 Mar 2023, 18:07
The sub-tick update system won't affect EMI, since EMI would affect the local system being played on, not the remote server directly.
Also, serious EMI issues would typically appear as frequent hard stalls/system freezes of 1 second or more (due to an increase in hardware-level error corrections), but let's not derail the thread with EMI talk further, or it will probably have to be relocated to:
viewforum.php?f=24
Kvcc0611
Post by Kvcc0611 » 29 Jun 2023, 18:44
Airon wrote:
10 Mar 2023, 06:40
Hello!
I have experienced over 4 years that the mouse feels heavy in CSGO. Mouse does not feel snappy and this comes over time. Many people believe that this has electrical causes, but that is not my case as I have tried my PC in 15 different places around the country (Norway). Mouse feels imprecise and feels like you have a dead zone that is similar to a puddle. I have 20 years of experience with PCs and have tried to make many tweaks within BIOS, Regedit, Bcdedit, Gpedit.msc etc. I have had 7 different PCs throughout 2022 with different motherboards from all the different manufacturers, both AMD and Intel. I have replaced EVERYTHING! That would also mean video cards, monitors, ram, power supplies, mouse, keyboard, external network cards and sound cards, 3 different ISP’s. I have tried high quality UPS, power filters and I can say right away that it has nothing to do with the electrical or hardware! I've even had electricians here re-run tests with a device to monitor what happens when things are good and not good.
To my question:
When I have a discord stream or a youtube movie running in the background while I play, the mouse is ABSOLUTELY perfect. The entire gaming experience is completely changed. Screen is VERY clean, Why??? There is no screen tearing, heavy mouse, the mouse is snappy and everything is 100% good. If I turn off the discord stream, things are just as bad again after 1 minute. It should be said that when things are good, I watch someone else's discord stream. I have tried time resolutions, hardware acceleration both on and off, but this makes no difference. I've tried monitoring which resources are running when things are good and when things are bad, but can't see any changes. I suspected at first that it might have something to do with interupts, but I have brown MSI Tool to enter variable interupts, but this is not the cause. The same problem happens if I stop using the mouse for 40 seconds and then start using it again, the mouse is perfectly fine and snappy, but gets heavier and heavier over time (1 minute). Why??
The only thing I wonder is why the mouse is perfect, and the game experience 100% good when I look at someone else's discord stream while playing? Its like when i use my mouse when things is good, i can shake it with 0 deadzone and its very fast.
Are there any clever minds out there who have an explanation for this, and how it can be solved?
And yes, i have mouse acceleration turned off, and high power plan activated.
Thank you in advance🙏🏼
Did you find what causes ?
